Hello there,
this winter we have several calls for C-3102 and C-3101 at C6500, C6501, C5500 and C5501.
The solution in some cases is different. Some cases replacing fixing gears can work and some cases replacing CDB or fixing motor will fix our problem
Do you have same issue? I think something with humidity and temp.
Does anyone have any idea what is the cause of this issue?
thanks in advance
thanks in advance
