konica 7022 with f35-4 error code
+ More Options
Posts
  • HUNG99
    • Aug 2025
    Hi every one !
    I have a photo machine Konica 7022 with error code f35-4!
    pls show me how to solve this problem with detailed instructions! Thks
  • skirt_chaser
    Fuser temp too low.
    Could be a dirty thermistor inside the fuser ass'y or a burnt out lamp.
    Couple of easy things to check first. If the thermistor is dirty, clean it with a cotton swab and alcohol, and make sure it is in it's proper position.
    You'll often find it caked with spent toner.
    • CMB
      KonicaMinolta Tech.
      • Mar 2005
      • 457
      http://www.copytechnet.com/forums/ko...codes-30s.html
      • HUNG99
        konica f35-4
        Thank a lot for your help. I will check it out ! See u later
