konica bizhub 350
  • mrgene
    • 53
    konica bizhub 350
    this is what i get when I work on non ricoh machines.
    I installed a new drum and develober ran f8 but am still getting a c 2557 ?
    any advice would like to recoup the price of the drum and developer at least lol
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    Did you try, with the machine powered up, closing the left door with the image unit out of the machine, and the display reads " Install drum cartridge" or something to that effect. Then resetting the drum & developer counters. Then install the I.U. and quickly running F8 ? Give that a whirl. These copiers are very routine sensitive.
    Kevin900
    • rocky246
      • Feb 2007
      • 91
      Just wondering. Did you reset the drum and developer counters?
      • mrgene
        • 53
        do not really know how to reset the counters
        • copytechman
          • Nov 2008
          • 929
          In service mode > Counters > Special parts > IC counter, reset to 0... or no end of troubles. Dev counter increments automatically with F8 function. (IIRC)
          Regards!
          A.
          • mrgene
            • 53
            thanks guys did what kevin said and it worked if you ever need ricoh help give me a shout
            again thanks
