C253 cannot boot
  • Dimitar_Andonov
    • Oct 2009
    • 10
    C253 cannot boot
    Dear friends,
    Have a problem with BH C253. I tried to yupdate firmware using CF card, but when i put card in the slot and turn on the machine, nothing happened. Display stayed black and star button light orange. I wait about half an hour, but nothing changed. Since that moment i couldn't start the machine. Try with diferent CF cards and different firmwares. Try to make NVRAM clear and recovery, but nothing change. Can you help me with adwice? Thanks a lot !!
  • DCPS
    • Mar 2008
    • 116
    Did you change the MFPB before or did this happen suddenly? You don't even have the sandglass on the display?
    • RRodgers
      • Jun 2009
      • 1947
      Try turning the copier off.... holding down the utility button and turn it back on, keep holding down the utility key (for a while) you should eventually see "Trouble reset" (I hope) if not.....
      Ummm....
      • Dimitar_Andonov
        • Oct 2009
        • 10
        DCPS and RRodgers, thanks a lot for ideas! Problem with the machine hapened suddennly. A day befre i tried to adjust Print area, but machine didn't response correctly to my intervention. No sandglass appeared- absolutely black hole. I try to enter trouble reset function, but with no success. I think that boot sector in MFPB was broken... any ideas how to recover it?
        • RRodgers
          • Jun 2009
          • 1947
          Does it sound like it's trying to boot? Might be a dead screen.
          • kmcopier
            PSP
            • Oct 2008
            • 183
            try R6 boot firmware, if that doesn't solved it MFPB!!
            • Dimitar_Andonov
              • Oct 2009
              • 10
              RRodgers I heard only fans on the start and retraction mechanism of transfer roller. Kmcopier, is this some kind of special firmware? I try only with mass production ones. I didn't see such in infohub suport. RRodgers and Kmcopier, thanks a lot for replays!!!
              • vijaysharma
                • Sep 2008
                • 61
                Replace the NVRAM its fix the problem
                • SmellsHot
                  Head Tech
                  • 512
                  start with operation panel!!!
                  Everyone has the right to be stupid. Some people just abuse this privelage more than others
                  • Dimitar_Andonov
                    • Oct 2009
                    • 10
                    SmellsHot, thaks for idea, but i'm sure that panel is ok, i checked it. Vijaysharma, i'll try with new NVRAM. Thanks a lot to both of you!!!
                    • Dimitar_Andonov
                      • Oct 2009
                      • 10
                      NVRAM is OK......HMMM. Any ideas?
                      • copytechman
                        • Nov 2008
                        • 947
                        If the ram chips, nvram and hdd are ok, and you've tried firmware... unless... did u ever unplug the control panel cable from the mfp board, that'll do it too, reseat the control panel cable @ both ends. Otherwise then all your left with is a damaged mfp board.. been there, done that!
                        Regards!
                        A.
                        • Dimitar_Andonov
                          • Oct 2009
                          • 10
                          Thank Copytechman!!! Wish me luck.... I'm going to hell now
                          • Dimitar_Andonov
                            • Oct 2009
                            • 10
                            Helloo friends,
                            Boot of MFP board was died. We change MFP and.....vollla....it works!!!. Thanks for help, all of you!!
                            • RRodgers
                              • Jun 2009
                              • 1947
                              Glad it worked out for ya.
