c6500 code on startup
  • copiers4africa
    • Jul 2009
    • 47
    pls help have any one experinced this problem before...and what was the solution...pls
  • fuckthesystem
    What service code?....in case you are refering to a bizhub Pro C6500!
    If not, what engine are you having problems??
    • copiers4africa
      • Jul 2009
      • 47
      c6708
      • Techead42
        • Mar 2008
        • 32
        This code is Image Processing related...possible points to T-Shoot below, with potential board replacement:
        C-6708* AOC/AGC adjustment abnormality
        • Blocking cover and lens
        cover of scanner section are
        out of place.
        • CCD board (CCDB) connector
        is disconnected.
        • CCDB power cable is disconnected.
        • CCDB IC protector is broken.
        • Quantity of light of exposure
        lamp (L1) is excess.
        • L1 does not light up.
        Image processing board
        (IPB)
        I/F board (IFB)
        Image memory control board
        (IMCB)
        Overall control board (OACB)
        Scanner drive board (SCDB)
        Printer control board (PRCB)
        Inverter board/1 (INVB1)
        Hope that helps.
        • jotunn
          • 618
          1. try to update firmware to the latest version, there are the same errors in other Konica Minolta machines (Bizhub 600, Bizhub 601 series and Bizhub Pro 1051, 1200) - worth a try in this case also...
          2. check for failed or loose connection between exposure lamp and inverter board
          3. check exposure lamp
          4. check inverter board
          5. check connector on CCD board
          • boxster964
            • 7
            I just had this code I had to replace the image processing board. I had a lamp that would come on flash for a second then coded C-6708 had level 60 software.
            • copiers4africa
              • Jul 2009
              • 47
              thank you ..taken your advice and got machine sorted ....
              • backspace
                • Jul 2009
                • 54
                I had this problem, I replaced the ex.lamp and solve the problem.
                • drodas78
                  • Jun 2008
                  • 91
                  Hi, what have you done to fix it? I have a C5501 with same problem here. Can you provide me with the latest firmware for it?
                  Regards
