Konica 920 printing w overlay causes code 72-16...
  • methogod
    • Dec 2008
    • 922
    We have tested everything.... from clutches to rollers....
    When I print normally, it will print fine - I can print 20K without any issue from any tray.
    When I print a mailmerge, using OVERLAYS - it will print a few from 5-100 then code out with a 72-16 code. When we take off the finsiher the codes moves to 32-01 through 32-04
    We have swaped finishers and fusers. Replaced conveyence clutches, LCT clutches, Replaced the registration clucth.
    Our thinking is the printer prints slightly slower when using overlay, i have 3 other 920s printing overlays without issue. Any ideas will help...
    I have all the manangement docs attached, let me know if you need any other information.
    Will paypal $100 for the correct solution - if its ok with forum...
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    I would check the following between the machines. The firmware versions of the print controller and the image controller. Also do you have the em-701 kit installed?
    • methogod
      • Dec 2008
      • 922
      Print controler is maxed out at 512 (1 stick), I dont know if it has the EM-701, where can i check it?
      • methogod
        • Dec 2008
        • 922
        Update: Fixed it for a while
        We swaped HDD1 (which is the copier's HDD) not the print controler and it worked for around 50K clicks, did overlays, 2 page overlays, everything that I needed for.
        Now its back to the same 72-16 code. I really dont get it. Nothing has changed.
        Any advise or what to try next.
