C253 with FS-519 C11A0 codes.
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    My customer's machine is getting finisher jams, but on the counters, no jams show up. I get C11A0 codes ( finisher out-put roller failure ) . I thorougly cleaned the gears, one-way bearings and shafts in that section, just as the bulletin dated March 15 suggested, to no avail. I appreciate any help you can offer. I want to get this resolved before the customer loses faith in me and her new equipment.
    Kevin900
  • Albonline
    • Sep 2008
    • 1153
    try replaceing the spring clutch that drives the holder paddle. 4349 2014 01 also check that the photo flag is in correct time/position in relation to the paddle drive system.
    • dogsbody
      • Jun 2007
      • 289
      I had to change M10 - 9J08031701 MOTOR Page 6 of the parts manual.
      Cheers
      The force will be with you always.
      • JSC
        Gimp
        • Dec 2006
        • 618
        Try cleaning the spring clutch first, I've have quite a few of these that have been caused buy to much grease in the clutch and it slips. make sure you note the posision of the clutch so its not out of sink when you refit it.
        Good luck
        The gene pool could use a little chlorine.
