Biz 350 Print runs uphill
  • eg101
    • Jan 2005
    • 131
    Have a Bizhub 350. No, It's not a color copier. Print runs uphill across the page in the feed direction when copy from the glass. Lead edge registration is perfectly square, but on a letter size page the tail edge has moved 3mm uphill.
    I guess it's a mirror problem, i've checked the cables and they appear O K. Anyone seen this?
    BTW the copier was shipped from another town directly to the customer so it may have had a rough ride.
  • Darren King
    copiertech
    • 652
    I have seen the font left edge of the scanner bed get bent downward. Sometimes a quick lift on the corner of the scanner bed will put it back into alignment.
    Hope this helps
    Darren
    • brent
      • Nov 2008
      • 1214
      could you please scan a pic of a test chart. would like to see this. I had a di 3510 do this. it is probably a mirror. for sure.. but you can of course narrow it down. if it prints ok and makes test patterns ok. then you know it is the optics. I fixed one and ordered some new metal tabs to keep the mirror in place. but then we mo ved the machine. then it was back to crap again.
      brent
      • eg101
        • Jan 2005
        • 131
        Thanks for the suggestions, I thought it was a mirror but visually couldn't see anything. Next time I'm at the customer I'll check it out.
