c6500 fuser replacment
  • cama
    • Aug 2025
    At what count should the fuser be replaced on a C6500?
  • ni311
    • May 2008
    • 658
    You don't have a deadline for the whole fusing unit in the service manual. But, from what I am remembering, fixing roller lower and paper exit roller should be changed at 200k, the fusing belt and sleeves 400k, gears and ball bearings at 600k.
    Konica Minolta Error Codes - Explanations and Solutions
    • cama
      I'm almost at 2 million and I have only changed the belts.
      So I guess that is pusing it?
      • ni311
        • May 2008
        • 658
        You are very lucky if your fusing unit is still working after 2 million without changing anything else but fusing belts. It is pushing it a little too much, you should have ready gears, ball bearings, sleeves and sensors near by. Anyway, it is a wonder that all the gears are still working and still are in one piece.
        • deep
          • Jun 2008
          • 208
          Wow......I just couldn't believe it.
          Kenny
          • seniortech
            • Dec 2007
            • 180
            Fuser units in my machines run happily 800K to 1 million copies without any problems...
            • ni311
              • May 2008
              • 658
              I'm not so lucky, I always have issues with the fusing units around every 200k.
              • sbillis
                • Nov 2008
                • 95
                that sound very good but, what kind of paper stock is using on these machines please?
                anything cheap or specific provided paper?
                • Herrmann
                  • Jan 2006
                  • 792
                  There are three gears with a "one way clutch" in it, i would recommend you to replace them every 600k copies, otherwise you can run into c-3102 errors
                  If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
