Error code P-8
  • USITC
    • Jul 2025
    Error code P-8
    I have a Konica Minolta Bizhub C350, on my screen the service icon (little oil can) shows up. when i press it the screen shows code p-8, does anyone know what this code means?
  • racosta
    • 53
    P 8 is yellow image unit failure. Either you have a bad IU or there toner density level if off.
    • copytechman
      • Nov 2008
      • 945
      From da book:
      P-8: Yellow Imaging Unit failure:
      Relevant Electrical Parts
      Imaging Unit C
      Imaging Unit M
      Imaging Unit Y
      Imaging Unit Bk
      Image Transfer Belt Unit
      Step Action
      1 Select “Image Adjust” → “PRT Max Density” and, if the setting value is negative, readjust.
      2 Check the drive transmission portion of the Imaging Unit and correct as necessary.
      3 Clean the AIDC Sensor window if dirty
      4 Clean the contact of the Imaging Unit connector if dirty
      5 Change Imaging Unit.
      6 Change the Image Transfer Belt Unit.
      Regards!
      A.
      • USITC
        Got it! I ordered a new yellow imaging unit, hopefully that should do the trick!
        • cristachecri
          • Mar 2015
          • 31
          Re: Error code P-8
          Hello everyone . I have a very annoying problem, namely a Bizhub C454 equipment displays the P8 error after each stabilization. I mention that the transfer belt is new, used only original toners, brand new cmyk unit drive!!! The only part that is not changed is the yellow development unit, which I suspect is also the problem. Today I got hold of a yellow development unit and changed it but the result is the same. Do you have any idea what else I could do?
          • Synthohol
            Certified Konica Expert
            • 5840
            Re: Error code P-8
            make sure the IDC sensors are clean
            • cristachecri
              • Mar 2015
              • 31
              Re: Error code P-8
              They are clean... I also took them down to make sure they are clean
              • tsbservice
                Field tech
                • 8019
                Re: Error code P-8
                What do you mean by cmyk unit drive and why you changed that?
                • cristachecri
                  • Mar 2015
                  • 31
                  Re: Error code P-8
                  I changed all the cmyk cylinder units to see if the error still persists... the P8 error is there
                  • tsbservice
                    Field tech
                    • 8019
                    Re: Error code P-8
                    4 complete drum units - originals are quite expensive even if you used 4 black units and 3 chips. Aftermarket drum units or only cylinders or new OEMs? You left so many things unclear so trying to help is like pulling teeth.
                    • cristachecri
                      • Mar 2015
                      • 31
                      Re: Error code P-8
                      the change was made with 4 units of black cylinders to which 3 cmy chips were put. After each calibration that is performed, P8 appears
