C4101 error code Bizhub 350
  • Kenny
    • Jun 2009
    • 515
    Hi i have two 350's with this error code can anyone point me in the right dirrection ?
    We were told it might be a power board problem ? so changed that with no diffrence, machine starts up OK then when you try and do a copy the error code comes up
    any help would be greatfully recived
    thanks
    Dave
  • Darren King
    copiertech
    • 652
    C4101 is polygon motor failure. The book says to check connections, change printhead, or change PWB-A
    Hope this helps
    Darren
    • Kenny
      • Jun 2009
      • 515
      We have tryed everything the book says with no joy .... it's driving us nuts !
      • rocky246
        • Feb 2007
        • 91
        Did you install a Bizhub 350 PH? The 200 and 250 are different than the 350. Just a thought.
        • SmellsHot
          Head Tech
          • 512
          Just replaced a 250 PH unit this morning, got that error code when i tried to copy. I had one of the ribbon cables flipped the wrong way. Check that as well if someone was playing around the ribbon cable area.
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • rocky246
            • Feb 2007
            • 91
            How could I forget the ribbon cables! I got them reversed the first time I replaced a PH in a Bizhub 350! Dang I need a vacation!
            • Kenny
              • Jun 2009
              • 515
              STILL BLOODY WONT WORK, tryed all above thanks so far ! still the same code !
              any other sugestions ?
              many thanks
              • SmellsHot
                Head Tech
                • 512
                Did you replace the write unit?
                Does the machine come to ready state? and if it does, does the code blow as soon as an original in placed in the df or the start button is pressed?
                Make sure you have 2 ribbon cables and one connector running through back of machine from PH unit. Also make sure you have the correct ph unit installed.
                Here this is straight from Konica ...
                C4101 code at power up.
                Description:
                Solution:
                PROBABLE CAUSES:
                1. Failed PWB-A (Mechanical CB).
                Replace the PWB-A board (p/n 4040 0101 03).
                2. No 24V DC at PJ17A, pin 5.
                Replace the 3.15A fuse located on the power supply.
                3. Polygon motor in the Print Head Assembly fails to turn.
                Begin by checking the connections to the Print Head Assembly. Unplug and reseat all connections. If issue continues, replace the Print Head Assembly (p/n 4040-0751-00).
                C-4101 (C4101) at power up.
                Description:
                C-4101 at power up.
                Solution:
                CAUSE: Failed BCRS board.
                SOLUTION: Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
                Hope this helps!
