problem with dark area in c6500
  • gang1110
    • May 2010
    • 43
    when customer print for exp. coated paper 130gr with dark area it's stack in the fuser unit the problem
    is i got small gap in margin can i play with the gap or change somthing in the utility ? in heavy paper
    like 200 gr it's not happen thanks
  • random
    If this is on Fiery try 'toner reduction' setting. It is actually better to run a lighter paper weight.
    • gang1110
      • May 2010
      • 43
      it's happen when he use paper lighter the paper stick in the fuser becuse the he print dark background
      • ESA
        Sticks to the fuser? Is the client using laser gloss or press gloss? I can't see adjusting fuser pressure as the resolution here. I would try a different brand of paper same wieght, as well I would try different weight settings to see if paper passes at any speed. Last note make sure you run a few blank sheet between jams to clean excess toner.
        • gang1110
          • May 2010
          • 43
          thanks for the information i will try
          • sbillis
            • Nov 2008
            • 95
            what paper size? If is A4 try A4S (=A4R=A4 rotated 90 degree)
            try toner reduction or toner exposure.
            You can see also is black is made from CMYK or from pure black. Preffered to made on your file from K only.
            Nothing else can help you.
            Final solution heavier paper.
            • gang1110
              • May 2010
              • 43
              he use A3 gloss paper i think it's short fiber mybe this is the problem . what is the best way to check if it is short or long fiber in heavy/light paper ?
              • Herrmann
                • Jan 2006
                • 792
                Fold the paper in half. The
                paper will crease easily with the grain. If you fold
                against the grain you get a jagged edge.
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
