C352 lines
  • digicor
    • Jul 2008
    • 1159
    C352 lines
    I have replaced the trans belt, roller,ALL IU's cleaned all toner tubing,wst toner tubing,as of this morning and left the client with a good copy, 1 hour later the client calls to say there is pink line in every copy or print thats color and now the blk has all kinds of lines in it, i had the clien re-boot the machine it went to stableize and ready. same problem. there is no coding out, can this be a pws supp board issue or the large ribbon cable from the mfp? the tech i spoke with said this could be the prob. any thoughts?????
  • Albonline
    • Sep 2008
    • 1154
    the ribbon cable can be the cause. is there any developer in the collector box? if so then look at the hv boards. you say lines, are they fine lines like drawn by a pen or wide bands?
    • digicor
      • Jul 2008
      • 1159
      the pink line is a thick (1/4 inch or so) the blak is both thin and thick, im heading ther in the am to get a better idea, these are the clients estamations, im thinking its hv lines? but the pink?? im not sure... do possibly have the ribbon cable prt # thanks
      • Johnny_B500
        • Mar 2007
        • 24
        Is there any way you could post some test prints from the machine?
        • RRodgers
          • Jun 2009
          • 1947
          Pull the MAGENTA imaging unit out and check it. Also, use the corona cleaning wand on the magenta unit as well. (that little blue thing) Hell do them all for giggles.
          • digicor
            • Jul 2008
            • 1159
            i will post some images later today when i get back from the clients office
            thanks for all the suggestions,
