c-550 background problem urgent!!!
  • gang1110
    • May 2010
    • 43
    i have customer with background problem specsaily in glossy paper 250gr or 300 gr the problem
    shows sometimes. now the iu k+c+m+y new and the fuser is new the belt live somthing like 30%
    attached file if someone have solution thank's.
  • BIG PAPA
    Da Boss
    • 234
    If you stop the copy half way through is it on the copy? Can you see it on the belt?
    sigpic
    • gang1110
      • May 2010
      • 43
      i dont think it's from the belt i can't see it i play with background voltage black on -5
      • JSC
        Gimp
        • Dec 2006
        • 618
        Has the mod guide sheet ( A00H703400 ) been fitted next to the transfer roller? if not fit one. Try increaseing the second transfer voltage as a temp fix, to me it looks like a transfer problem, I'd also be tempted to replace the transfer roller as well.
        Good luck
        The gene pool could use a little chlorine.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Is it there if you do test prints from within the machines memeory? Like the printed meter or the gradation charts in test mode. If those are clean you could have issues with the OS.
          • gang1110
            • May 2010
            • 43
            why do you think there is problem with transfer roller ? and increasing the transfer voltage how match?
            • JSC
              Gimp
              • Dec 2006
              • 618
              Its not so much the transfer roller itself but the guide plate next to it. I've had a few of these machines give faults like the one you have and its been caused by static building up on the guide plate especially with thicker paper. If you just increase the second transfer voltage by lets say 2 or 3 steps you should see an improvment in the copy quality, if this is the case you know you are on the right track, the next step would be to fit the mod guide sheet or make one up your self and reset the transfer voltage back to the default setting.
              • Shlomo.s
                Hello!
                This model has a problem of development unit
                Try to download the black background to 5-
