Minolta Di550 : Need to replace web roller ?
  • youspaze
    • Sep 2025
    [CQ] Minolta Di550 : Need to replace web roller ?
    i have a konica minolta di 550 stopped working, and displays the following message:
    " Need to replace web roller " , I checked that roller and i found that more than the half of the "cleaner paper" on it not consumed yet ! so i've checked out every piece & gear in that web roller , Nothing broken, and cleaned the 3 "sensors" or whatever it's called, but still displaying that fatal error.
    Also , the motor of the web roller is rolling & it works fine.
  • youspaze
    Problem fixed!
    The problem is fixed, i just cleaned up the memory and it worked!
    • Tom
      • 344
      Sorry I saw this too late that you had to figure it out yourself. The minolta Di450, 470, 550 web roller goes by the copy count. You have to clear it out in the service mode under counters, but I guess you already you already figured it out.
