Konica bh 7145 f51-2
  • copierlady
    • 338
    Working in a konica biz hub 7145 keeps jamming (j30-0). Finally gave me a f51-2 code and i changed the fixing driver motor. But it is still jamming (j30-0) and occationally giving be a f51-2 code. Any ideas out there?
  • Techace
    • 32
    hi,
    this code for main motor speed problem, try to change the main motor or open the back cover and check any abnormality.
    regards
    Techace,
    • RRodgers
      • Jun 2009
      • 1950
      I just had this on a 7040. Turned out to be the dev drive bushing get gummed up and drag down the motor. It's easy to pull the dev drive out and clean/lube those up.
      • copierlady
        • 338
        Ok guys that gives me a direction to go. Why did i think it had something to do with the fixing drive motor? Got off track somehow. Do you have a part number for that motor? Don't want to replace the wrong one again! Thanks for the help.
        • RRodgers
          • Jun 2009
          • 1950
          If the motor is NOT spinning its the motor if its turning its the bushings.
          • copierlady
            • 338
            Thanks! Why are we on here?
            We are supose to be relaxing and regenerating!
