Bizhub 600, anoying customer after copying from glass.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I have not gone to see the machine yet, but the customer says that if he puts a small original on the glass and makes a copy, then removes it and try to make a normal size copy, the machine ask for 8 and half by 5 and half, even if you press panel reset , unless you lift the lid and close it a second time. None of his other Bizhub 600s do it so he wants it fixed, and he is the manager for a 325 machine contract. Has any one else seen this.
  • randall
    • Sep 2009
    • 73
    under the user settings>copier settings> "Auto paper size for small original" turn it off or set for 8.5 x 11
    Some people may say I have a short temper, but I prefer to call it
    "A swift and assertive reaction to bullshit"
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      In an effort to help someone in the future, I wanted to close this. The problem was the plunger and actuator that the doc feed depresses when you close it. I do not know why, I removed the assembly and checked it, and after I reinstalled it it began working correctly. I found it was the plunger assembly by noticing that when I lowered the lid slowly, I had no problem. Hope this helps.
