good idea for C350 first drawer
  • Rudi
    replied
    Originally posted by mascan42
    LOL !!!!
    Thanks for the nice tip connecticcut.
  • mascan42
    replied
    Originally posted by connecticcut
    I take cahoutchouc a feed (first drawer Ricoh 1224C). After removing (cutting it) big cahoutchouc minolta, I slide on the hub minolta feed Ricoh (easy to install after having doused with alcohol ).
    replied
    ... big cahoutchouc minolta,...
    ...cahoutchouc?
  • viva
    Guest replied
    Good help
    That is nice trick ! I am going to try it. Thanks for it !
    ________________________
    www.vivaprint.cz
  • connecticcut
    started a topic good idea for C350 first drawer
    to avoid stumbling jams with the paper thick3 10pts, install a Feed Ricoh copier on minolta copier (first drawer).
    I take cahoutchouc a feed (first drawer Ricoh 1224C). After removing (cutting it) big cahoutchouc minolta, I slide on the hub minolta feed Ricoh (easy to install after having doused with alcohol ). It is a little longer than the minolta but this does not alter the deranged operation.
    Your customers will thank you and will be able to use the thick3 without apprehension (to print the business card ).
