C550 with brownish strip at top and bottom of page p-21 code
  • lucky13
    • May 2008
    • 125
    the strips are the test strips being written on the belt right inline with with the front and rear color registration sensors top strip is cyan and yellow over lapped bottom is black and magenta overlapped .they are constantly being written over and over ,pulled out transferbelt and is spotless except for two bands going all the way around belt every copy or print job has these strips . also the high tones are washed out and giving a p-21 and no C codes ,also when printing and copying machine has a very loud high pitch whine and gets louder at the end of copy process . tested all iu's every color has stripes through them .transfer belt was changed out a few days earlier,customer still had the old one i swapped it same thing. had a printer controll board tried that .tried new firmware. i have an MFP board comming tommarrow and try that . im going to get some samples scanned in later to day .thanks for reading
  • tech51
    • 846
    Had this fault a few times now. Check the drive motor and gear assembly that drives the transfer belt cleaner brush. I would bet that the gears have stripped or the worm gear on the end of the motor is worn. There are modified parts available to prevent it happening again.
    • Albonline
      • Sep 2008
      • 1153
      yes, this sounds like the same thing ive seen a few times. it seems to happen on tbelts that have been fused 2 or three times.
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        I agree with the previous two replies, might be a cleaning brush issue.
        Also, check in tech rep to ensure that belt cleaning is turned on. It can also help to step up the positive and negative cleaning bias levels a notch or two.
        And though rare on this model, look to ensure your metal contacts for bias are making full contact to the HV unit.
        It could also mean HV is failing. Though I have my doubts.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • lucky13
          • May 2008
          • 125
          here are the samples ,it seems the belt is getting cleaned after every print or copy job no ghosting or print residue. just that the strips are being layed down as its cleaning .did not have a chance to put in printer controll board today im going to look at those drive gears also thanks guys.
          • Albonline
            • Sep 2008
            • 1153
            looking at the scans , It seems to be the cleaning system is working, think you my need the mfp board,
            • tech51
              • 846
              Having seen your scans I`m even more convinced its the gears. Its the noise that gives it away, as it cleans at the end of the copy cycle it gives out a high pitched whine that varies in pitch as the cleaner drive speeds up and slows down again. Dont know why the stripes appear like this but every one ive had has had stripes like this. As I said the gears have been modified to prevent this fault, Our favourite theory is that if the black IU fails (as they do from time to time) developer gets carried via the transfer belt to these gears ans accelerates the wear on them. We now remove the transfer belt and remove any dev residue if a black IU has failed. One other thing, I did have one where the gears where ok but the drive motor gear had worn, make sure you chek that too. Let us know how you get on. Cheers...
              • lucky13
                • May 2008
                • 125
                tech51 you were dead on checked thoes gears and the 55t gear was worne down in several places and it was the old style assembely i have all the new style parts comming over night thanks again . just strange i have never ran in to that before ,i must have 300 this type machines in our area never seen it ill post the bullietin for others
                • Stirton.M
                  • Oct 2009
                  • 1804
                  Cool. Cannot say I have ever encountered this problem as described in teh TSB, but thanks for the information just the same....
                  ---Groucho Marx
                  • RRodgers
                    • Jun 2009
                    • 1947
                    I remember back in the 8031 days I would have to replace a t belt because someone would put the waster toner box in wrong and it would back up and break the auger in the t belt cleaning station. So, be sure to check the waste box and make sure that it's going in correctly and that they little tube that leads to it is going in right.
                    • Stirton.M
                      • Oct 2009
                      • 1804
                      The waste toner bottle on the C550 is a front mount unit with 5 ports in it, one for each colour and one for the belt cleaning unit. These are fool proof now and pretty easy for most users to figure out. Open the front main door, two spring tabs to hold it in place. Pop the tabs and it comes out. The bottle will go in at an angle without much fuss or damage to the recycling section.
                      the 8031 is the same design found on the CF3101/3102 and C350/C351 and C450 machines.
                      ---Groucho Marx
                      • c-tom
                        Thanks lucky13 and Tech51, I had this same problem flipped the 55t gear around for temporary fix until the parts get in.
                        • rindraintsoa
                          • Sep 2010
                          • 55
                          Hello all,
                          I also have the same problem with my C550, and hope that it wil work on my machine, just one question, how this band can be placed inside the paper margin because I think that it is the registration bar printed automatically by the machine to check the registration so it should be outside the printable area
                          • Ianizer
                            • Jul 2011
                            • 380
                            Re: C550 with brownish strip at top and bottom of page p-21 code
                            Hm. Same issue with a C451... Turned out to be the Transfer belt unit. Replaced it -- problem gone.
                            -I
                            My name Peggy.
                            You got problem?
                            • habik
                              • 2013
                              I think we had this issue here
                              If it does this kind of noise than it is definitely the drive motor for the cleaning brush.
                              see the video:
                              Firmwares HERE
