I am new to KM and was handed a call for a C451 to replace the black IU. The drum is completely coated w/ toner and the image is solid black when copying. Tried doing other colors w/ the same result, any ideas?
black copies on C451
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
Paul@justmanuals.comComment
Bring an IU with you.
In some cases, the IU itself might be the fault regarding the codes. If the IU was stored on end for example, so all the starter packs up at one end, it can prevent the developer from turning and stalls the motor. Shaking the IU front to back while level sometimes can fix this without issue.
In other instances, such as yours, starter from the chamber has started to pull out between the drum and mag roller of the dev section of the IU and enough has built up to create excess friction related to drum rotation. If this is the case, the IU has to be replaced as there is no way to determine how much starter has been pulled.
To prevent the second problem in the future, when replacing the IUs, make sure they are seated firmly. I give them a firm shove when sliding them into the machine, before engaging the lock lever. In many cases where I have encountered a starter pull situation, usually the black IU, the IU itself has creeped forward because it was not locked properly in place. Drum and developer bias lose contact with the machine, and starter can be pulled as a result."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
There is an FOC bracket that Konica sent out to us to keep the Blk IU's from "creeping out" I think it was on a C451. I'm pretty sure it was on a C550 box.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Thanks Guys! I have been a Kyocera rep for more than a while, starting off with these Konica's has got me feeling like a noobie, I have no support here at the shop, all the techs (including me) are hacks - good hacks, but hacks none the less. I am thankful for the help.Comment
