C3B02 fault on Konicaminolta c452
  • jrf
    • 142
    Hi everybody,
    Has anybody had this fault, i am waiting for an IH power board which i hope will repair it but just wondering if you had any other cause of it.
  • KEVIN900
    Copier Ninja
    • Oct 2009
    • 200
    Hey jrf, the manual says to check, in this order; proper fuser installation, proper closure ( door latch ) of the right hand door, check around-all around-for wiring connection issues, change fuser, then coil, then IHPU, then PRCB, then REDB. If you have a trade-in, or lease return, at the shop; it might pay to do some parts borrowing.
    Kevin900
    • oem
      In the cases we faced, we replaced the IHPU and the coil unit. We were told that the coil units were okay, so replacing the IHPU must be enough to recover.
      • jrf
        • 142
        Thanks for replies, just to let you know the IH power supply sorted this problem but i also replaced the coil unit as it has blown on some C451 machines
        • neunelf
          • Mar 2010
          • 8
          hi
          i had this code 4 times! 3 times it was the IHPU board and 1time it was the fusing unit self.
          regards
          • jrf
            • 142
            Was it the fuser or the coil unit neunelf ?
            • neunelf
              • Mar 2010
              • 8
              3 times the IHPU and 1time the fusingunit, NOT the coil. i didn't have a defective coil till today.
              greets
