not recognize the cyan in C-6500 please Emergency!!!
  • gang1110
    • May 2010
    • 43
    the machince not recognize only the cyan we change image board, control board we discoonect hdd
    we change the laser and replace the image unit+dv unit nothing change when we print in test mode cyan we get white blankt if anybody have a solution?
  • mrwho
    Major Asshole!
    • 4299
    When you say you print in test mode, you're refering the engine test mode and not the controller, correct?
    Mascan42
    Ibid
    • gang1110
      • May 2010
      • 43
      yes
      • mrwho
        Major Asshole!
        • 4299
        Check for anything blocking the laser path (and if the laser isn't somehow misalligned). Also check the cyan drum ground - without ground, the drum is prone to make blank copies.
        Mascan42
        Ibid
        • seeb
          • Nov 2009
          • 41
          Are you getting any error codes?
          • gang1110
            • May 2010
            • 43
            when we run proccesing we get sc28-03
            • mrwho
              Major Asshole!
              • 4299
              Of course that's to happen if one of the colors isn't developed. You can also check all the connectors on the right side of the machine (the four white and blue connectors to the right of the paralel and network ports).
              Mascan42
              Ibid
              • gang1110
                • May 2010
                • 43
                we check already those connoctors in the right side were is the image board and hdd its ok
                • gang1110
                  • May 2010
                  • 43
                  somebody have athoer idea
                  • HORSE
                    • Mar 2008
                    • 185
                    Have you checked that the Cyan 1st Transfer roller has not fallen out of its holder in the Transfer Belt?
                    Also you could try to Panic stop the machine to see any image has been formed on the drum. Start with the simple stuff and work your way back.
                    Laughing......
