Konica c500 SC45-09
  • jzheld
    • Sep 2010
    • 162
    [Error Code] Konica c500 SC45-09
    Any idea how to get rid of it, original got sc45-20, 45-09 appeared when I did auto color adj in 36 mode.
    Any suggestions?
  • jma676
    Expert Tech
    • Mar 2009
    • 323
    Konica Minolta Bizhub Pro C500 Error SC-F4520 - F4509
    Description: C45-20 occurs
    Cause:Abnormal termination of color registration control.
    1. Normal registration mark is not made on the transfer belt, The sensor can not read it because registration mark is not made correctly on the transfer belt.
    Defective parts:(Transfer belt, Drum, Developer, Developing Unit,etc).
    2. Defective color registration sensor.
    3.
    Defective printer control board.
    4. Defective writing unit.
    Description: C45-09 occurs
    Cause: When the laser correction motor /Cyan (M9) was ON, laser correction HP sensor /Cyan (PS7) was turned OFF.
    Relevat Parts:
    *Printer control board (PRCB)
    *Laser correction motor /Cyan (M9)
    *Laser correction HP sensor /Cyan (PS7)
    You are creating serious problems with this. Be careful or contact a technician.
    • jzheld
      • Sep 2010
      • 162
      Thanks for your help, trying not to create any problem, I got the machine basically for free, it been in terrible conditions, already change a lot on it
      • jma676
        Expert Tech
        • Mar 2009
        • 323
        Ok, I understand, then tell me and went out.
        You are Canadian?.
        No Problem.
        • jzheld
          • Sep 2010
          • 162
          Thank a lot man for you help, it worked, it prints not a really good quality but prints, so that is a good start, I think I will be able to fix the rest, at least there is no errors. I live in Toronto, but hasn't been born here
