Bizhub c350 registration issues
  • molsonreddog
    • Oct 2010
    • 11
    [CQ] Bizhub c350 registration issues
    Any input from your techs on this?
    C350 8 1/2 x 11 is ok but from 11 to 17 color reg goes crazy. Tried cleaning all sensors and firmware update.
    I saw this once before on another machine and firmware fixed problem, but not this time.
  • molsonreddog
    • Oct 2010
    • 11
    Is everyone stumped by this one?
    • mo0651
      • 1054
      What is the life counters of the IU's and transfer belt? Have you run any registraion correction? Is there any damage on transfer belt?
      • BIG PAPA
        Da Boss
        • 234
        Have you reset the machine and gone back thru running adjustments? 8.5X11 is ok? Have you adj fuser speed at all? Longer size paper might have a speed issue between reg and fuser? But yes what are the life counters at? Has anything been replaced, before or after prob started?
        sigpic
        • molsonreddog
          • Oct 2010
          • 11
          Machine only has 57k on it. Life counters are good on all. tried reg and fuser speed adj. with no success. FD zoom will adjust on a testpage, but doesn't affect the prints with color.
          • BIG PAPA
            Da Boss
            • 234
            Are you getting any P codes? Wont stop machine but will appear under the oil can. IDC sensor errors and the like. regardless of counts, if adjustments wont work would lean toward replacing belt. Do the motors slow down during process?
            sigpic
            • molsonreddog
              • Oct 2010
              • 11
              No P codes listed. machine had standard controller. I added a fiery for the customer then a couple days later they called about this issue.Thinking about bringing back to shop and testing next to working machine but that looks bad to customer.
              • ck1
                • 485
                did you check the led unit pin ( both side ) loose.... ?
                • RRodgers
                  • Jun 2009
                  • 1947
                  I see that problem here and there on C350's. The fix for it is to play with the fuser line speed. (in tech mode) That should fix it.
                  • Copier Doc
                    • Mar 2010
                    • 49
                    I agree with RRodgers, im not an expert on Bizhubs but have had similiar issues on C350 & adj fuser line speed did sort it in then end. Good luck
