bizhub 350 change drum question...
  • brent
    • Nov 2008
    • 1212
    so I know they go around 100k give or take. but I had one go 179k the other day and it did not lock up. the copy quality was shot. but I have had these machines lock up also
    is there a soft switch that I have turned off or on? thanks
    brent
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Brent, most of them will go way over if you do not reset the counters. In the soft switches, type 418 in the top box. In the string, bit 3 should be flipped to "0" and it will turn off the change PC message.
    • mrwho
      Major Asshole!
      • 4299
      That's nice to know. Since I usually run from those machines I never had the chance to look that up. It's already on my notebook!
      Reps to you!
      Mascan42
      Ibid
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Just remember that if it fails prematurely, look on the right side of the drum and look for a scratch where the drum has made contact with the mag roller, then you need a new box.
        • mrwho
          Major Asshole!
          • 4299
          Of that I was aware, thanks. I also know that you can replace the whole box or just rebuild the developer unit with new collars on the mag roller.
          Mascan42
          Ibid
          • SmellsHot
            Head Tech
            • 512
            What is the highest percentage you've seen before image quality goes bad?
            We average about 200% the highest we've seen is 279%
            Anyone getting better yield?
            Everyone has the right to be stupid. Some people just abuse this privelage more than others
            • brent
              • Nov 2008
              • 1212
              only had 179 percent. copy quality was shot. but also got to keep in mind. that unlike the 3510 series that you could in deed zero out the drum and deleloper counter. if you try to zero out these counters it will go into a code. then you would have to replace the drum and developer right?
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                Yes you are correct. When you change the drum and developer, "0" out the counters before you put the new unit in. If you put it in before doing that, it will code and it is hard to recover. You only get to adjust it once on these.
                • ezzysi
                  • Oct 2008
                  • 78
                  Hi, being quite new to the KM brand can I check where to go to access the soft switch for this function.
                  I've seen one listed in the manual under "Admin 2" in the Utility Admin section, is that the right place to make this change? and can it be switched off if the machine is already displaying the "change pc drum" message.
                  Cheers
                  Simon
                  • SmellsHot
                    Head Tech
                    • 512
                    You can change the switch in either admin or service mode, and yes the message will go away. Just make sure you cycle the main power after changing the switch.
                    • ezzysi
                      • Oct 2008
                      • 78
                      Thats great info, cheers all
                      • Hansoon
                        • Sep 2007
                        • 3374
                        **Shameless Push**
                        Lots of additional info here:
                        Follow the links inside too
                        http://www.copytechnet.com/forums/sa...di-series.html
                        Hans
