DF-605 problem on bizhub 350
  • aleksander
    • 378
    Hi all,
    I need your help for this crazy problem. I have bizhub 350 with optional DF-605 installed. This problem happened if I use the ADF for the scanner function (FTP, SMB, email), no problem for copier function. I attached the example file below. If I use the original glass, you can see the scanned file at the right one, and the other one is using ADF with auto-detect mode.
    If I placed the document in portrait direction using ADF, I've got a full page scanned file (scanned file 2.jpeg). But, if I placed it in landscape direction on ADF, You could see it below (scanned file 1. jpeg).
    I've already tried to change the PBA-CONT and DF-605 and MFBS and it doesn't work. Still same problem.
    Anyone know the solution for this one? Please Help.
    Thank you.
  • RRodgers
    • Jun 2009
    • 1947
    Am I missing something?
    • aleksander
      • 378
      what? you know the solution? t
      • RRodgers
        • Jun 2009
        • 1947
        ohhh... I think I see the prob now. Hmmm... firmware is were I would start first, then check your line speed adjustments as well as zooming. Be sure it's at 100% or 1.0.
        • aleksander
          • 378
          Same firmware with another bizhub 350. Could you tell me how to check the line speed adjustment? no zooming. Another solution?
          thank you.
          • aleksander
            • 378
            anyone have solution for this problem? Please help me.
            Thank you.
            • albasoul06
              SOLUTION: Replace slit plate glass (# 4551 2031 01) and perform the DF height adjustment.
              • aleksander
                • 378
                could you tell me how to perform DF height adjustment? thank you
                • albasoul06
                  you don't know to adjust HINGES ?
                  • aleksander
                    • 378
                    only Hinges? still not working
                    I change the slit plate glasses and still the same problem.
                    Any other possibility? thank you for solution.
                    • aleksander
                      • 378
                      I tried it but still not work well. Any other solution? Please help. very urgent.
                      • Hansoon
                        • Sep 2007
                        • 3391
                        I know its me but having read this post several times and just spending now 10 minutes to understand what the problem is, I don't get it.
                        Aleksander, what is the problem you have? Your description is confusing to me. If I print out the JPEG's and compare, I see a slight difference in width. Is that what bothers you?
                        BTW you could use a new testpattern. All those smudges are confusing too.
                        Hans
                        • aleksander
                          • 378
                          Hans
                          You can see and compare the the 2 JPEGs file and watch the right side/edge. Not full image.
                          Sorry Hans. Thank you for responding.
                          • Darren King
                            copiertech
                            • 652
                            Do a DF width adjustment. Hope this helps
                            Darren
                            • aleksander
                              • 378
                              I know the solution and it works well. Change the firmware to ver. 70
