shadowing when scanning or coping on c552 (non ds)
  • lucky13
    • May 2008
    • 125
    [CQ] shadowing when scanning or coping on c552 (non ds)
    when coping or scanning in portrate direction i get ashadow that runs along the top about 1 inch across page ,seems to be comming from rear of slit glass area , copy or scan on glass no shadow , checked doc feeder tried max up and max down no change ,tried reg loop adjustment no change , all rubber hole plugs are in cant see a light leak anyware ,if i move back ground removal all the way light it goes away but copies are washed out ,has firmware B4 ,sample is in color it also does this in B&W ,checked optics all clean no misaligned mirrors .this was a new install only 600+ prints on it
  • SmellsHot
    Head Tech
    • 512
    Have you done the "non image area erase" ? Do your internal prints look fine?
    I would also make sure your white reference is clean. It's weird that it's blue.....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • lucky13
      • May 2008
      • 125
      did not see the non erase image adjustment in the set up instructions i do see that when setting up B&W and the smaller color machines,i'll go back and look for that adjustment , and i did clean both sides of glass , yes all prints and internal prints are fine
      • ebm
        • Apr 2007
        • 183
        You seem to have isolated the problem to the ADF. I wonder, does the shadow come out cyanish in black or single color copies also? If so, what could cause it to come out that color? Just something to ponder which might help isolate the problem further. I could be mistaken, but, Don't you have to remove some bluish tapes from the ADF at setup for this model?
        • lucky13
          • May 2008
          • 125
          not shure if its doc feeder or slit glass area B&W copies and scans have a B&W shadow and all packing tape is off thanks
          • Stirton.M
            All things Konica Minolta
            • Oct 2009
            • 1804
            If the problem only appears during ADF scanning and is fine on the main platen, it could very well be an issue with the doc feeder not sitting correctly. You will need to verify that all four "feet" of the doc feeder are sitting flat against the top of the scanner unit. The left rear is the most difficult to see...when the feeder is closed, shine a light on the front edge to direct that light between the scanner and doc feeder and look through from the back to see if there is a gap.
            Also check to verify if the white guide is moving freely...it is spring loaded with two shoulder guide screws holding it in place...
            "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
            ---Groucho Marx
            Please do not PM me for questions related to Konica Minolta hardware.
            I will not answer requests or questions there.
            Please ask in the KM forum for the benefit of others to see the question and give their input.
