C462 squeak ee fuser
    • 30477
    got a squeak in the lower drive gear, that keeps coming back
    is there a fix?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    There is an FOC part for fuser noise. It changes it from gear to belt drive. It has stopped alot of the noises from the drive side of the fusers. I think I used my last one and will have to look up the part and order another.
    • Millennium
      • 30
      I am guessing you mean the C452:
      The Tech Bulletin is #7676. The FOC part number is A0P0R90100. They should also send you a bottle of Drysurf lubricant that you will use during the mod process.
      • jgillilan
        squeek
        also while you have it apart clean the shaft and bushings for the fur cleaning brush put some dryserf on the shaft and bushings too.
        • David Morrison
          Digital Tech II
          • Feb 2010
          • 43
          Re: C462 squeak ee fuser
          What would that part number and tech bulletin be for the VL4522C (it's equivalent model)?
