Hi all, has anyone seen this on a c350. The grey band on the lead edge only happens on the first print/copy out of a run. If I do single colours it only appears on black but again only on the first print of a run. Internal test prints are OK except the K print which will have the dark band on it. The machine has recently had a transfer belt fitted, but I`m leaning towards the image unit being faulty. Any input would be appreciated.....
Grey band on C350
Swapping the unit, even with a used one is the easiest way to eliminate the issue. It could also be a bias issue with the transfer belt cleaning section. Perhaps removal and inspection of the tabs and buttons, cleaning them with alcohol may fix this. Even simply removing and reseating the belt. Stranger things have happened. It could also be a problem with the erase lamp for that unit."Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
---Groucho Marx
Please do not PM me for questions related to Konica Minolta hardware.
I will not answer requests or questions there.
Please ask in the KM forum for the benefit of others to see the question and give their input.
