bizhub c360
  • yousaf
    • Jun 2010
    • 43
    bizhub c360
    hi
    how i can set the copier default black and white printing. right now its on auto but i want black printing as default. copier is Bizhub C360 any body help me i am stuck with the color copier
    bye
    yousaf
  • bizhub1
    • Sep 2008
    • 230
    Are you asking about the copier default screen or when printing? If you want to change the copier mode to default to b/w, go under utility, user settings, for printing change it in the driver
    • mo0651
      • 1054
      touch color tab, set black. then utility/counter key, user settings, copier default, current setting. set
      • yousaf
        • Jun 2010
        • 43
        thanks man
        today i fix in utility user setting then copier setting u c both option current setting and factory default i fix it
        bye
        thanks
        yousaf
