Konica minolta biz hub 420
  • copierlady
    • 338
    One of those weeks i keep running into brick walls!! Working on two 420's in the same office that will not duplex 8.5x11. It will duplex 8.5x11r and 11x17 no problems. Is something set on these machines that will not let it use this size (direction) of paper? And ... How do you adjust the paper drawers on these machines? Both of them are printing way to the left, unless you use the manual feed tray. I know..............brain dead this week! Thanks.
  • copytechman
    • Nov 2008
    • 944
    If it's jamming on ltr only especially i'd go after the 2 duplex transport mag clutches... been there done that... timing is more sensitive with ltr than ltr-r, lgl or 11x17!
    Regards!
    A.
    • ineo+6501
      • Mar 2010
      • 262
      Yep, the mag clutches on these are a known weakness
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Change both clutches, it will work again
        • copierlady
          • 338
          Ok guys, thanks alot. I thought you might say that but i wasn't sure because it was duplexing other (bigger) sizes. Just takes someone who has "been there done that" i guess, thanks again.
          • mrwho
            Major Asshole!
            • 4299
            Perhaps it duplexes bigger sizes because the paper is being pushed by the previous rollers, aiding the failing clutch.
            Mascan42
            Ibid
            • copierlady
              • 338
              Hey ya that is a thought.
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                It is the timing. All the other positions and sizes except normal portrait ,are slower and the clutch is able to keep up.
