bizhub 250 copy faded
  • avio2
    • Jul 2010
    • 150
    I have a machine that makes copies of faded bands beginning with clear verical and then tends to make them completely faded, I have already changed developer and drum + clean corona charge and controlled the path toner perfect copies I made about 1000 and then resumed to do so
    this machine have 100000 cp, any ideas ?
    ps in A3 faded shorter in the sense
    tank's
  • mo0651
    • 1054
    developer units are known to fail on these models. could be a bad spot on guide rollers. scan in a pic, let us have a sample.
    • SmellsHot
      Head Tech
      • 512
      replace transfer roller!
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • kingarthur
        • 1385
        Check that the "brass" connectors on the door are making proper contact with its opposite on the m/c, we've had m/c's where these have been deformed, causing "washed out" copies
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          Transfer roller
          • avio2
            • Jul 2010
            • 150
            thank's i had already changed the stransfer roller but , the problem was the connector developing roller in machine
            tank you very much and excuse me for possible speeeling error but i'm italian
            enrico
