Bizhub C350 Clicking, but dead
  • mrfuser
    • 1617
    We have a C350 at a client that just makes a clicking sound, but will not power on. Dead Power Supply perhaps?
    Any suggestions?
    Kelly
  • mrwho
    Major Asshole!
    • 4299
    Blank screen or does it show anything at all?
    The clicking sounds like a relay on the power supply, so that's definitely the most likely possibility.
    Mascan42
    Ibid
    • mrfuser
      • 1617
      Blank screen. Nothing showing up.
      Kelly
      • mrwho
        Major Asshole!
        • 4299
        This might sound dumb, but check the connection between the scanner and the main body - if it is disconnected, it will not show anything on the control panel, sounding like a power malfunction.
        Mascan42
        Ibid
        • mrfuser
          • 1617
          checked that. Just swapped power supplies with a known good and same result. Power supply clicks on and off. Tried opening doors and closing, tried unplugging scanner and back in, all same result. Something is stopping the power supply from activating completely.
          Any thoughts?
          Kelly
          • mrwho
            Major Asshole!
            • 4299
            Try to disconnect all the peripherals and turning on the machine with all the doors and trays opened.
            Mascan42
            Ibid
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              I suspect a short someplace. It could be an overload condition causing the PSU relays to switch on and off, a protection routine as it were.
              The cause could be quite literally any of the electrical components. Visual inspection might reveal an obvious issue, but don't expect this as the norm.
              ---Groucho Marx
              • Jemmi Anderson
                • mrwho
                  Major Asshole!
                  • 4299
                  Years ago I had a 7060 doing exactly that because the sensor for the lower right door was broken and it was shorting against the chassis. It happened twice in a week and the symptoms repeated.
                  Mascan42
                  Ibid
