Bizhub 250 Fax Driver Available?
  • mrfuser
    • 1598
    Okay, client asked us to install an FK503 fax kit. We ordered the kit, but can't find a fax driver for faxing from PC anywhere. I even checked the Europe site to no avail. Is faxing from PC not an option on the 250?
    Thanks all!
    Kelly
  • mrfuser
    • 1598
    Okay, I found this file, on KM Europe. Why they can't put it on North America I have no idea. It claims it is for many models, one being the 250. So here is the link for anyone in the future scrambling to find it.
    Download Result - Download Center | KONICA MINOLTA
    Enjoy all!
    Kelly
    • Hansoon
      • Sep 2007
      • 3349
      Until now didn't find a solution to use Networkfax with W7. With XP it works fine.
      Hans
      “ Sent from my Intel 80286 using MS-DOS 2.0
      https://www.copytechnet.com/images/smilies/biggrin.png
      • aesthetics1
        • May 2010
        • 148
        Have you attempted to run it in Compatibility Mode?..
        • Hansoon
          • Sep 2007
          • 3349
          Most of the customers have W7 Home Premium which doesn't have the Compatibility Mode isn't it? Or am I misinformed?
          Hans
          • pepper38_cnd
            Field Service Manager
            • Aug 2005
            • 1075
            The Network Fax Utility is available on the SSD under "UTILITIES" and it appears anyone who upgrades to a 64 Bit OS is out of luck as it just won't work. If anyone has found a work arround for this please share.
            Now into Ip TV KODI Boxes
            • aesthetics1
              • May 2010
              • 148
              Konica Minolta's regular Network Fax drivers for even their newer machines have issues on 64-bit systems. For example, you cannot add a fax cover sheet using the utility with a C220/280/360 series fax driver.
              I haven't heard of compatibility mode being disabled in home level Windows versions - it has been in all versions that I know of since Vista.
              • Hansoon
                • Sep 2007
                • 3349
                See under W7 Professional. The XP mode starts from here.
                Windows 7 editions - Wikipedia, the free encyclopedia
                Hans
                • aesthetics1
                  • May 2010
                  • 148
                  I'm not referencing the XP mode, I'm referencing right clicking on the application, selecting properties, and running the install as well as the program itself in "Windows XP Compatibility Mode"
                  EDIT: Semi-unrelated, this works for Pagescope Pro (The cheesy bloated FTP Server that KM used to bundle for FTP scanning) on Windows Vista, 7, etc... Although I advocate using the FTP Utility or another third-party tool.
                  • mrfuser
                    • 1598
                    Network Fax
                    Okay, installed Kit, can fax from machine no problem. Went to install network fax utility and it seemed to install okay, but we can't get it to fax from any of the workstations. Client is running XP. I tried adding the ports in the firewall per Konica instructions and still we get nothing.
                    The box pops up and says "server connection error".
                    Any thoughts out there?
                    Kelly
                    • aesthetics1
                      • May 2010
                      • 148
                      I would imagine you haven't configured the settings for the program. You need to go into the program and go to the tools menu to set it up I believe. It has been a long time since I have used that program, but I remember having to plug in the unit's IP Address before being able to fax out. Try poking around the menus to see.
                      • mrfuser
                        • 1598
                        Yes I have done that. Still does not work. The manual for the 250 says it should.
                        Kelly
                        • aesthetics1
                          • May 2010
                          • 148
                          Can you show me a screenshot of the error you're getting and also when you're getting it? I'm a little confused.
                          Your steps should be:
                          1. Open a document (Word, etc.)
                          2. File > Print > Select the Network Fax Printer (Whatever it named itself.)
                          3. Select Print, you should get a verification screen with a thumbnail of the document, and you should have a checkbox at the top to confirm sending.
                          4. The network fax utility should launch, and you should hear the copier beep as it receives/sends the fax out.
                          Where are you getting the error, and can I see a screenshot please?
                          • mrfuser
                            • 1598
                            I am using network fax version 4.5.35. Sorry I can't do a screen shot and input it here. Not sure how from this clients PC. It pops up a window and says "server connection error". Then it counts down to try to send it again. Is there a different utility and/or driver I should use for the bizhub 250?
                            Kelly
                            • aesthetics1
                              • May 2010
                              • 148
                              I have 4.6.1. Let me try this out here and see what results I have. Give me just a bit!
