C552 blows building circuit breaker
  • mascan42
    • Oct 2008
    • 481
    [Dead] C552 blows building circuit breaker
    I have a customer whose C552 is blowing the circuit breaker immediately on power-up. The sub-power switch doesn't need to be turned on, just hit the main power & the breaker trips half a second later. If the front or side doors are open, the breaker doesn't trip until they're closed. I've tried replacing the IH power unit, the IH coil, and the DC power supply. One of my fellow techs thinks it may be the HV unit, but I wouldn't think that would come on immediately before even the MFP board. Any ideas?
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Maybe check the fuser to make sure nothing is shorte. I think that's the only 120v circuit that comes on immediately on power up.
    Parts: Its what your copier craves!
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      I had one did the exact same thing I had to replace the fuser coil and driver board for the coil, located front right of machine.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        Along with the above, what is the amperage of that circuit breaker? It should be 20A. Also, is there anything else sharing that circuit breaker? If so, take those and plug them someplace else. This machine is a power hog.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
