KM C450 black image problems
  • lanierboy
    • 149
    [CQ] KM C450 black image problems
    Hello Everyone,
    I have a customer with a C450 Minolta machine, colour prints are fine but when we do 80gsm black only we get some halo's and smudging around the text.
    thick paper setting seems to be unaffected, i have changed the fuser loop sensor as i have had that cause this before and the fusing unit is new.
    anyone had this before??
    cheers
  • mrwho
    Major Asshole!
    • 4305
    First try to wash the black printhead with a moist pad and then clean it dry. The reason why this could affect only one type of paper is because the machine adjusts toner density on heavier papers, so a dirty printhead could not show on heavier paper. If that doesn't work, try to swap the black IU with another (used) one to see if the problem changes.
    Mascan42
    Ibid
    • ddude
      General Troublemaker
      • 473
      There have been problems with the IUs-
      2000 mockingbirds = 2 kilomockingbirds
      • stryker3k
        • Jan 2011
        • 11
        There was problems with the IU's a while ago, but I agree with mrwho above....A simple clean of the K LED will most likely fix it.
