konica1212
  • cliffhangers
    • Feb 2010
    • 242
    konica1212
    it have problem with corona wire the corona wire is there bet it copy blank please i need your help on this konica1212 thanks in advance.
  • crismoncy
    • Oct 2010
    • 18
    try to check the charging corona unit and transfer/separation unit maybe one of that wires worn out.so it will cause blank copy.
    • ddude
      General Troublemaker
      • 473
      Can't remember, but if there is a cleaning pad assy, it may not be seated in home position, causing the short-if present, run the cleaner back-and-forth.
      2000 mockingbirds = 2 kilomockingbirds
      • mrwho
        Major Asshole!
        • 4305
        Didn't those machines have a recurring problem where a gear on the back of the machine would get stuck (when opening the machine) and wouldn't give movement to the drum unit, causing blank copies?
        Mascan42
        Ibid
        • mrwho
          Major Asshole!
          • 4305
          More tips:
          DESCRIPTION: Blank copies.
          PROBABLE CAUSES:
          1. CN32 at the HV unit is disconnected. Reconnect CN32.
          2. Currents cannot be adjusted. No output from the high voltage unit. Replace the HV unit
          PROBABLE CAUSES:
          1. IP2 on main control board open, preventing 24V DC from reaching HV unit.
          2. Check the Transfer/Separation contact springs located at the rear of the T/S corona Unit. Expand the contacting springs to ensure sufficient upward pressure.
          Mascan42
          Ibid
