Konica Minolta C6501 - C4501 / C4502 error code
  • punchi.com
    • Jul 2025
    Please could someone help me, i am getting codes C4501 / C4502, replaced both write units and did the write unit initial position prodcedure, ld bias, i/o check, etc. checked the ICP's with board out and machine on, wiped all dev or toner off the dev units, replaced the color registration sensor assy, checked the transfer belt is not scew, am stuck!
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    The following TSBs entries may be of value in this issue
    Description
    C-2211, C-2212, C-2213 or C-2214usually when the machine is running in Thick Paper mode (1/2 line speed). These are drum drive error codes.
    Solution
    PROBABLE CAUSES:
    1. Incorrect drum speed.
    Please instal minimum version 40 firmware to correct the drum speed.The latest version firmware is available via the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'. After installing the firmware please set the following DIP SW to the recommended setting:
    DIPSW21
    bit 6 bit 7
    0 0 Default
    1 0 0.1% up
    0 1 0.2% up (Recommended)
    1 1 0.3% up
    If the symptom reoccurs with the recommended value, try the 0.3% UP setting.
    2. Cleaning blade has "flipped" on a corresponding color.
    3. Incorrect Belt Line Speed Adjustment setting.
    Check the setting by referring to section 10.3.8 Belt Line Speed Adj. (Printer Adjustment) in the Service Manual. If the setting value is not in the range between -5 to -35, readjust the value within -5 to -35. If -5 to -35 cannot give the satisfactory result, also perform the section 10.3.3. FD Mag. Adjustment (Printer Adjustment).
    4. Failed Drum Drive Unit.
    Replace the Failed Drum Drive Unit (p/n A03U R757 00 for Yellow / Cyan ) and p/n A03U R758 00 for Black / Magenta ).
    C-4520 error code at power up. With poor copy quality, lines, wrinkles. The transfer belt may mis-track or slide toward one side or the other ("walking" off the rollers) during color registration adjustment, after performing a PM.
    possibly with C-2714 error code. No image is visible on the transfer belt.
    possibly with C-4501, C-4502, C-4503 and/or C-4504C-4501, C-4502, C-4503 and/or C-4504 error codes.
    PROBABLE CAUSES:
    1. Open ICP fuse on the Printer Control Board (PRCB). Check the continuity of the ICP fuses ICP17, ICP20, and ICP21 with the PRCB out of the machine. You can also carefully check that there is 24V DC on each side of the fuses while the board is in the machine. Voltage on just one side of the fuse would indicate that the fuse is open and the board needs replacing (p/n A03U R75911 - Printer Control Unit).
    2. If [09 Writing Init. Pos. Memory] is not performed, the adjustment value is not reset to the initial value. Consequently, adjustment margin is decreased in some cases. When the write unit is replaced, clean the dust-proof glass and perform the following adjustments in order:
    a. Writing Init Pos. Memory
    b. LD Bias Adjustment
    c. I/O check mode
    d. CD Skew Adjustment
    e. Restart Timing Adjustment
    f. Color Registration Adjustment
    g. Color Registration/Manual (Adjustment)
    h. Auto Gamma Adjustment
    Possibly with C-4521 and/or C-4522 error codes
    CAUSE: ICP17 is OPEN on the Printer Control Board. The wiring between the printer control board and the hardware counters may be pinched. If the wire is shorted to ground, ICP17 on the printer control board will open, resulting in the error code. If the wire is broken internally without shorting, the machine will function but the counter will not increment.
    SOLUTION:Check the wiring between the PRCB and the Total Counter. There might be a short to ground close to the Total Counter. After the short is found and repaired, replace the PRCB (p/n A03U R759 11).
    If the wiring is not damaged, reposition it so that it is secured in the plastic hooks behind the counters. This will keep the wiring from being pinched when the cover is removed and reinstalled. It is recommended that all machines be inspected at setup or the next service call to prevent future incidents.
    Description
    C-4501 yellowlaser correction failureoccurs after running the "Both Sides" paper tray adjustment.
    Solution
    CAUSE: The error occurs because the adjustment was not completed prior to running test copies.
    SOLUTION: To correct the problem, perform the following procedure:
    1. Select the Machine icon on the control panel.
    2. Select the Both Sides icon on the lower part of the control panel.
    3. Input the paper tray adjustment values.
    4. Select Chart Adjust.
    5. Select Adjustment Start.
    6. Select Close after the adjustment completes.
    7. Select the Copy icon and run test copies.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • punchi.com
      I have tried all the procedures attached above - no joy?? any thing else i can try??
      • engineer
        • May 2011
        • 19
        have you check the wiring between the printer control board and the write unit may be pinched, if you have try all that mention above, better you try to replace PRCB.
