Konica 7130 pm
  • SKTeK315
    Walter
    • Jun 2009
    • 142
    Konica 7130 pm
    7130 needs drum, blade & DV. Can anybody help with the procedure please. Tnx
  • Luther
    • May 2006
    • 682
    I suggest you get a manual this isn't easily explained, drum is kind of a bear if you haven't done it before, and remember the drum and dv are good for 200k the web is only 100k and usually needs a fuser rebuild so every other pm is dv.drum.and blade and every 100k pm add a web and fuser rebuild, you also need to reset drum count and run l-detect and reset pm count fuser roller count and web count when doing the web fuser roller dv and drum change...hope this helps
    • SKTeK315
      Walter
      • Jun 2009
      • 142
      Thank you. Yes it does but I also need the modes & what. I don't have the manuals. Thanks again. If you can help, it would be grest
