C220 Transfer Belt Trouble
  • CKiiza
    • Feb 2010
    • 77
    Good day to you.
    Got a number of C220s out there that have developed A STRANGE Illness. The transfer belt gets a very rough surface as seen in the attachments, that it's captured in the printouts. Thee problem occurs in some new machines with in the 1st 20,000 copies or those machines in which the transfer belt gets replaced.
    Any one seen this and solved it before? Thanks for the help
  • huntergazz
    • Feb 2011
    • 23
    Hi,
    I have not seen this problem with the belts. The common one I have seen (10-15) is where the sep claw punctures through the belt, gives a mark on the print that looks similar to a staple. If your a dealer you can claim under warranty.
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      Just a guess, but maybe an environment issue. Ozone?
      "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
      ---Groucho Marx
      Please do not PM me for questions related to Konica Minolta hardware.
      I will not answer requests or questions there.
      Please ask in the KM forum for the benefit of others to see the question and give their input.
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        Yeah that's a new one for me too. Could be dust or maybe the paper type maybe. I have only seen the claw problem. One time we unboxed a machine and had a bad belt(bent contacts) out from the go. Does it throw up any P. codes?
        • CKiiza
          • Feb 2010
          • 77
          Thanks for the responses, The separation claw puncture has been common but this is strange. The machine won't give any warnings and it won't show very vividly at first except for solid artwork. Been thinking too that this is due to environment issue. Trouble is that I have been tasked with finding a solution. So wondering where to start. Any Ideas?
          • copytechcns
            Probably a pointless question but will you get the same problem again if you replace the belt ie. is something in the machines killing the belts, or is the belt itself simply faulty and failing (maybe a bad batch of belts?)
            Do you have a belt that successfully did its entire life? You know thats a good one, wack a new fuse in it and put it in one of the problem machines and see if it develops the same problem?
            If its the machine thats killing the belts (seems unlikely if you have multiples, unless someone is fitting them incorrectly or something) you'd probably have to look for something rubbing on the belt first.
            • dejanmonte
              Re: C220 Transfer Belt Trouble
              Hi,
              I have also a belt problem on my Konica Minolta Bizhub C220.
              The transfer belt have a hole that is captured in the printouts. I intend to buy new belt transfer unit, but I'm not sure how to replace it. Maybe mechanical part is not so difficult to be repalced, but is there any special setting or reset to be done after unit been repalced ? I'll appreciate so much if somebody can help me !
              • wseyller
                • Sep 2012
                • 1129
                Originally posted by dejanmonte
                Hi,
                Should get a service manual. Transfer belts are too expensive to just wing it. Follow the instructions for replacement, reset procedure and gradation adjustment.
                Transfer belt also comes with a new transfer roller and ozone filter.
                Sent from my DROID BIONIC using Tapatalk
                  • 22999
                  I'd have to agree with Compy. Maybe they're using some sort of coated media type that's transferring to the primary belt?
                  I had a customer call the punctures "mustaches". They do sorta look like mustaches. =^..^=
