Hey everybody. Kon 7130. Changed dru, blade & SV. Cleared counts. Set date. No how ti do ATS/ATDC adjustment. Haven't done 1 since the merge. Appreciate the help
Kon 7130 ATS/DV adj
albasoul06
Thanks alot. When I was at the Mach. Today doing the pm, I sort of thought that L is the ATS adj. but wasn't sure. Couldn't find anything that resembled auto toner sensor adj. So I turned it on normally. Yes it coded out. I tried l adj. The right side of screen says 60 or 600 but the left side after start read 0006. Without runing. How do I redo ?
Thanx againComment
Clean the sensor in the drum cariage and then run L detect againOnline Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
The sensor on the TCSB is dirty, resulting in improper output to the PRDBie drum sensor... if that is clean your main motor has failed!!! also check your dev unit is rotating!Comment
