What's up everybody. 750 had c4707 laser code. Changed laser, corrected code prob. Now no warm up, no codes. Waited 5 min. No code. Trouble reset for the hell of it. Same. FSR stays cold cwhats going on with this thing ?
BH750 warm up
Sure all the doors are closed? Check circut breakers in back? Fuses?Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
got this from KM's site
Description
Warm-up sequence is stuck at the Konica Minolta logo screen.
Solution
CAUSE: Failed Scanner Driver Board.
SOLUTION: Replace the Scanner Driver Board (p/n 57AA-9090).If the problem persists replace System Control Board CF Assembly (p/n57AE -952 0) and
System Control Board (p/n 57BA -906 1 for a bizhub 600 and p/n 57AA -906 1 for a bizhub 750 ).
Description
'Now Warming Up' message. C-2801 (C2801) may also be indicated and copies may be "gray".
Solution
CAUSE: Dirty or failed Toner Control Sensor Board.
SOLUTION: Check Service Call Counter 28-01 (Maximum Density Correction Error 1) for excessive counts. Clean or replace the Toner Control Sensor Board
(p/n 56AA 9102E).
these might helColor is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
jgillilan
Check your connector on the main body that the fuser plugs into when you slide the adu back in, I have seen those break and cause the same problemComment
