white line on copy at black outpu
  • gabski
    • Aug 2025
    [CQ] white line on copy at black outpu
    hi, i have a problem with bizhub c200, everytime I print a black document, there is a white line on copy, the width of the line is almost half an inch, I have already cleaned the developing unit of the imaging unit bt still white line appears.... any one could help me?... thanks in advance
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Sounds like a main charge issue or laser slit is dirty
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • hussain
      • 28
      Originally posted by gabski
      hi, i have a problem with bizhub c200, everytime i print a black document, there is a white line on copy, the width of the line is almost half an inch, i have already cleaned the developing unit of the imaging unit bt still white line appears.... Any one could help me?... Thanks in advance
      clean the laser slit glass and try
      • minimerlin
        • 851
        Is the cleaning stick for the laser slit glass complete? Maybe the pad is stuck in the laser path?
        Please do not PM me without asking first.
        • jsw2k
          • Oct 2008
          • 95
          Ditto the previous replies, especially if the line is well defined.
          • mrwho
            Major Asshole!
            • 4299
            I'd bet on a piece of paper or something like that on top of the laser glass. As other said - clean it!
            Mascan42
            Ibid
