Bizhub C351 Auto Gradation won't run
  • mrfuser
    • 1622
    Anyone ever seen the auto gradation not output a test page for scanning on the C351? It seems to go through the process, but nothing prints out. All supplies are fine, the machine works fine other than that.
    Kelly
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    It seems to me that originally it would only output on 11 X 17 from either tray 1 or the bypass I can't remember which. Then firmware changed and it would output on 81/2 X 11 if Leger wasn't available.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • RRodgers
      • Jun 2009
      • 1947
      Yeah, try that.
      • mrfuser
        • 1622
        Doesn't matter what is loaded, it won't output a chart.
        Strange things these copiers!
        Kelly
        • acusso1234
          Tecnico
          • Dec 2008
          • 250
          Make sure that : Imaging process Adjustmennt / Dev. Bias Choice is in "OFF" position.
          If not, you are not able to run calibrations. I've seen this on a C 300, but the menu is the same.
          Hope this is your case.
          ... In the minute that you're thinking of giving up, think about why you lasted so long ...
          • mrfuser
            • 1622
            Yes it is off. if it is ON, you won't even see the option to AUTO GRADATION on the screen.
            Kelly
            • acusso1234
              Tecnico
              • Dec 2008
              • 250
              Maybe a reset and a reinstallation...I hate this, but sometimes it helps..
              • mrfuser
                • 1622
                Okay, get a failure in Grad Adjust in service mode. Looks like both front and rear IDC sensors are failing. Anyone know where they are located?
                thanks
                Kelly
                • acusso1234
                  Tecnico
                  • Dec 2008
                  • 250
                  1)Take out tansfer belt unit.
                  2)Idc sensor (front and rear)are located at the right of Black iu.
                  3)Open the steel mask and clean them whith air.
                  4)Power on and if P5 or P21 is not displayed try the calibration.
                  • acusso1234
                    Tecnico
                    • Dec 2008
                    • 250
                    You can take the manual here:
                    MEGAUPLOAD - The leading online storage and file delivery service
                    • mrfuser
                      • 1622
                      It was the IDC Sensors. Both VERY dirty. I saw the errors under WARNING in service mode. Good catch ACUSSO1234!
                      Kelly
                      • acusso1234
                        Tecnico
                        • Dec 2008
                        • 250
