Anyone ever seen the auto gradation not output a test page for scanning on the C351? It seems to go through the process, but nothing prints out. All supplies are fine, the machine works fine other than that.
It seems to me that originally it would only output on 11 X 17 from either tray 1 or the bypass I can't remember which. Then firmware changed and it would output on 81/2 X 11 if Leger wasn't available.
Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers. Now into Ip TV KODI Boxes
Yeah, try that.
Make sure that : Imaging process Adjustmennt / Dev. Bias Choice is in "OFF" position.
If not, you are not able to run calibrations. I've seen this on a C 300, but the menu is the same.
Hope this is your case.
... In the minute that you're thinking of giving up, think about why you lasted so long ...
1)Take out tansfer belt unit.
2)Idc sensor (front and rear)are located at the right of Black iu.
3)Open the steel mask and clean them whith air.
4)Power on and if P5 or P21 is not displayed try the calibration.
