Touch Screen Swap C350 vs C352
  • mrfuser
    • 1625
    Does anyone know if the C350 and the C352 touch screens are the same?
    Kelly
  • DadO
    • Dec 2007
    • 404
    Bizhub 252 and 352 has same screen.Swaped it lasst week. and for C350, It looks the same enought U wont know for shure till you open it.
    • kingarthur
      • 1383
      I've used the C352 touchscreen in a C450, which as far as i know is the same as a C350
      • dogsbody
        • Jun 2007
        • 289
        C450, C351, C250, C252, C352 and C300 all use common touch panels #4037780701. The touch panel isn't listed in C350 parts manual, just a unit that looks like the display panel as well.
        Cheers.
        The force will be with you always.
        • DCPS
          • Mar 2008
          • 116
          C350 has for sure a different touch screen (4036 7830 01) same like Konica 8022. You see it's an older model.
