Web Scope login error
  • Green Hornet
    When attempting to login as admin to one of my copiers I recieved the following error:
    Cannot perform service.[Sub Switch is OFF]
    Any ideas?
    Thanks.
  • RRodgers
    • Jun 2009
    • 1947
    Any ideas?
    Thanks.
    Does it have a stuck print or fax job? Is the memory at 100%
    • mo0651
      • 1054
      is it on?
      • Green Hornet
        RRodgers -
        Fax function is disabled and there are no jobs in the queue. The machine has been rebooted several times. I can successfully ping the machine. I've successfully logged into Web Scope for this machine as admin before.
        Thanks for the quick reply.
        • Green Hornet
          Originally posted by mo0651
          is it on?
          It's on and I can get into Web Scope public access. The issue is only when trying to log in as admin.
          • RRodgers
            • Jun 2009
            • 1947
            IE or Firefox? Try Firefox.
            • Green Hornet
              Unfortunately FF is not an option for me here at work. I manage about 110 Konica's though and log into all the others through IE with no problem. I've even logged into this very machine, from IE, as recently as last week with no issue.
              It's a bit of a head scratcher. If I haven't come up with a solution by tomorrow I'll have to call in a service tech.
              • RRodgers
                • Jun 2009
                • 1947
                IE is ALWAYS a problem for me, if you can, can you try opera maybe?
                Maybe try clearing your browser cache (on IE) and see if that helps.
                • Green Hornet
                  Well, I cleared the cache, and I'm in!
                  Thanks for the suggestion RR.
                  • aleksander
                    • 378
                    check the firmware, try to rewrite it.
