BizHub 250 IU
  • copyman
    Owner / Technician
    • Sep 2005
    • 4618
    BizHub 250 IU
    Can I take an Image Unit with 26k from one machine and put it in another with the "replace IU message"? If this can be done what else has to be done before resetting life counter to get rid of message on display?
    Thanks in advance
  • perdana
    • Jan 2008
    • 62
    No. you can not. You must change Pico fuse inside IU conector.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4618
      I don't think this image unit has a fuse? I know the "di" 250 does
      • perdana
        • Jan 2008
        • 62
        Yes, Copyman right, Bizhub doesn't have fuse. You only disable the indicator before they shown by setting Software Sw.
        • ck1
          • 485
          you can reset the counter from techrep mode , but must change drum and developer , do F8
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            to turn off the message go to soft switch settings,enter 418 for the mode or top number, the change bit 3 to a 0 and reboot the main power.
            • tech51
              • 846
              Thanks in advance
              Is this a C250 (colour) or a BZ250 (b/w)? Only reason I ask is that the BZ250 messages "change pc drum", whereas the colour machine says "replace IU". Please clarify the machine type to get the correct advice...
