KMBH c452 Warning: No Animation Data Available, Contact Your Administrator
  • tech51
    • 846
    Re: KMBH c452 Warning: No Animation Data Available, Contact Your Administrator
    Originally posted by femaster
    While different generation machines had different methods to do updates, this model should be new enough to use USB. The firmware and movie data should be installed via a USB thumb (flash) drive. (I'd have to check the manual to be 100% sure, but I'm 95% sure without looking). There would be a "service" USB port that should be located right next to the regular ones, but covered by a sliding metal plate.
    This is for main body firmware only.
    animation data is done in tech rep mode.
    • Desert Rat
      • May 2008
      • 1089
      Naturally when I try to do something I have never done, I start getting service calls. Finally after about 8 weeks or more of really
      slow time.
      I will feel more comfortable with this after I get a chance to read the manual and see the procedure. I was reading through
      the procedure for the BH C353. I need to find my flash card and figure out how to use it.
      Every bit of information helps so
      Thank you for your input
      DR
      • darry1322
        • Oct 2010
        • 817
        slow time.
        DR
        The procedure for the C353 and the C452 differ. The C353 uses a CF card , the C452 use a USB thumbdrive. You may already know this, but I wanted to clarify.
        Try to keep your thumbdrive at 2GB or less. I have used a 4GB drive successfully though.
        • Desert Rat
          • May 2008
          • 1089
          #19
          Darry1322,
          While I did figure that out from reading the C353 manual. It did not mention
          that detail. And with the devil in the details, it is better to have all the details.
          I do have a couple of thumb drives and one of them is 4gigs.
          How big is the firmware file?
          Thanks for your help and thanks to everyone on these boards.
          Teamwork makes the big difference.
          Thank you very much
          DR
          • darry1322
            • Oct 2010
            • 817
            #20
            I don't have that particular firmware on hand, but probably around 610MB. Animation file would be around 1GB.
            • Desert Rat
              • May 2008
              • 1089
              #21
              darry1322,
              Thanks for that info. I'll look for a 2gig drive.
              DR
              • femaster
                • May 2011
                • 1514
                #22
                Thanks for the correction. It had been a long time since I had done the movie data, and had to do it again just yesterday when I realized my error. You are correct.
                Sent from my XT1254 using Tapatalk
                • krakcy
                  • Nov 2013
                  • 19
                  #23
                  Hello all,
                  I also need that movie data for C-452.
                  Can anyone provide a link to it?
                  Thanks in advance!
