konica7145 paper jam from all cassette and bypass.
  • atech
    • Aug 2010
    • 89
    [Jamming] konica7145 paper jam from all cassette and bypass.
    Good day! first of all I'm not really familiar with Konica 7145. Its my first encounter with this problem, paper jam from all cassette and bypass. I check the feeding and I have observed that the pick up roller was not rotating. At first the machine will normally operate,but when I make a copy it indicates paper jam immediately. I checked the paper path sensor and cleaned them already, I have also checked the feed motor and its ok.but still the same.
    anybody have an Idea and would be kind enough to share it with me.thank you so much... I badly need help... thanks.
  • CraigW
    • Dec 2010
    • 417
    Possibly an open ICP on the printer driver board. I solder on a pico fuse across the open ICP still left on the board.
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • copytechman
        • Nov 2008
        • 947
        Likely drive motor or icp as previously stated.. usually machine will indicate a paper jam before a motor failure... been there, done that!
        Regards!
        A.
        • atech
          • Aug 2010
          • 89
          thanks craigW, you're right, Its pico fuse @ ICP...thanks a lot buddy!more power...
          • atech
            • Aug 2010
            • 89
            thanks a lot copytechman, ICP fault..
            Regards!
            A.
